[T] I'm going to try for 10 cartridges
A project log for Liquid Laminate Lithography 3D Printer [gd0105]
The best of resin with the best of filament; is such a 3D printer possible?
kelvinakelvinA 07/19/2022 at 18:450 Comments
Everything about the printer except the application, collection and washing of resin is more-or-less standard stuff. The exclusions are things that could only really be fully tested when inside a system (imagine trying to find a good FDM 3D printer bed material by using a 3D pen). With only 8 cartridges, 1-bit colour is the only thing I can think of presently that I won't be able to try out.
I'd like to attempt 10 cartridges over 8 so that full 1-bit colour could theoretically be supported. It also allows me the option to leave a 2 or 3 high cartridge installed for print jobs that use a frequently used colour, such as white.
Now knowing this, I plan to use MGN9C for all linear motion. I'd imagine it'll make the BOM slightly less daunting to tackle.
2x300 for the rollers, 4x400 for the Z, 2x500 for the X axis and 4x600 for each set side of cartridges. The cartridges also get 4 additional MGN9C carriages. The roller linear rail length is the only one I've confirmed in CAD for now.
