[T] Merge Application Rollers with Screen Block
A project log for Liquid Laminate Lithography 3D Printer [gd0105]
The best of resin with the best of filament; is such a 3D printer possible?
kelvinakelvinA 08/03/2022 at 00:100 Comments
A new solution has been detected...
The wide distance between the roller shafts on the Screen Block I just modelled made me realise that, with the right optical endstop and PET roller setup, I could eliminate the independent application rollers. I'm using optical endstops everywhere because they're quieter and give me the opportunity to move past the endstop if needed. My idea is to have a long strip that extends from [x axis limit] all the way to [absolute max x axis limit].
Benefits
Potential hurdles
