[A] [T] Current BOM Price (and more scanner sensors)
A project log for SlimeSaver [gd0105]
Combining MSLA and LOM to eliminate the time spent cleaning the slime.
kelvinakelvinA 08/01/2022 at 05:440 Comments
I've added in a few components, such as SuspenseSmall exclusives and new things like the 10 contact image sensors. Oh right I haven't mentioned it in the previous log, but I'm thinking that there would be a real benefit on debug/testing and features (explained below). I've also seperated the quantities into Suspense and SuspenseSmall so that it's possible to track an estimate to either. The Small will likely cost more if components were sourced by themselves.
Since each sensor is about £4 after tax and another hackaday user managed to get a fraction of data off of it (see the log comments), I'm just going to assume that it'll work fine. With this assumption, I'm thinking of adding a sensor to each side of the LCD head which will allow these possible features:
Additionally, one sensor could be put inbetween the area where PnP components are stored and the build area so that the arm just has to swipe anywhere in the 210mm scanning area for the computer vision software to obtain an image, thus hopefully the arm is already in place by the time the software has calculated the rotational adjustment needed. It may be possible for the X axis to scan the just-placed part to confirm that the component was placed correctly, but a component might be sticking out in the Z and damage the screen
