I've also got to think about how the block with be attached to the X axis slider.
[A few mintues later]
Hmmm and I would've gotten away with it too if it wasn't for that meddling plastic tab on the CIS. It's not like it would've helped much if it was ommitted anyway. I wont be suprised if the SuspenseSmall ends up being 605*605*305mm (H*L*D). Maybe small enough to put on a table or one of those "heavy duty" shelves on ebay, but relatively large compared to the print area. At least it should still compete well against the Photon M3 Max, which has a 9mm shorter X and 70mm longer Z axis.
[23:47] I just realised that since I've got scanner sensors on the screen block, I can actually remove the need for scanners between the application roller and screen block. That's £17 saved and 60mm of X footprint that can go to something else.
