[M] Updated Bed Assembly
A project log for SlimeSaver [gd0105]
Combining MSLA and LOM to eliminate the time spent cleaning the slime.
kelvinakelvinA 07/24/2022 at 20:350 Comments
Now I can use a 4040 extrusion and only have to move less than half the distance of the original roller. The ballscrew has around 330mm of linear motion, so I'd have 305mm of Z height currently. My silver target for build volume is to meet or exceed each axis the Proton M3 Max's build volume. The gold is over 325mm in Z and 450 in X.
