A SuspenseSmall roller assembly has also been created.
The current allowable Z height is 334mm for the Suspense and 185mm for the SuspenseSmall. These could be increased by 7mm if the rails were 7mm longer. The Small footprint height is expected to be around 500mm.
Being able to share components reduces the additonal modelling time for the SuspenseSmall.
Just found out that the distance between the back of the Z rails is 370mm for the SuspenseSmall. I'm going to have to think of a new solution.
