1Step 1
current test code running on arduino
int Distance = 0; // Record the number of steps we've taken
void setup() {
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(8, LOW);
digitalWrite(9, LOW);
void loop() {
digitalWrite(9, HIGH);
delayMicroseconds(50);
Distance = Distance + 1; // record this step
// Check to see if we are at the end of our move
if (Distance == 3600)
// We are! Reverse direction (invert DIR signal)
if (digitalRead(8) == LOW)
digitalWrite(8, HIGH);
else
// Reset our distance back to zero since we're
// starting a new move
Distance = 0;
// Now pause for half a second
delay(1);
NeoRazZ
