1Setup
In this example, we first connect Ameba to WiFi, then we use Ameba as server to communicate with client.
First, we make sure the correct Ameba development board is set in “Tools” -> “Board”
Then, open the Simple WiFi Server example in “File” -> “Examples” -> “AmebaWiFi” -> “SimpleServerWiFi”
In the sample code, modify the highlighted parameters and enter the ssid and password for your WiFi connection.
2Step 2
