Control boards and power board.
Fluid ferromagnetic display.
MagneticControl (01.10.2022 12-18-00).zipThe design of the controller board for controlling the power section. Project created in Altium Designer 20.2.7x-zip-compressed - 1.15 MB - 10/01/2022 at 09:20 |
MagneticBoards (01.10.2022 12-10-52).zipThe design of the board for controlling magnets. Project created in Altium Designer 20.2.7x-zip-compressed - 1.03 MB - 10/01/2022 at 09:13 |
We managed to collect the first number. Unfortunately, there was not enough liquid for the rest of the numbers. A volume of 20 ml is enough for only one segment. At the same time, it is difficult to lift the remaining liquid from the bottom, so more than 20 ml is needed. That would remain a sufficiently high layer of magnetic fluid. Current consumption is about 2 amps per digit at 100% PWM. In the following experiments, I will try to reduce power consumption by reducing the PWM to 50% when hitting the drop in place, since it takes less power to hold the drop than to lift it.
First display test. Test of the first section of magnets.
Debugging the software and hardware of the device. Firmware is being developed.
Milling the top case for liquid electromagnetic watches. Material oak and mahogany.
