Available
06/10/2022 at 09:50 • 0 commentsBD sensor can be pre order now,the first small batch will be available next week.
Thank you very much for your support.
the same size as usb typeC
06/05/2022 at 06:32 • 0 commentswow,the same size as usb typeC
new
06/03/2022 at 01:28 • 0 comments -
New Shell
05/30/2022 at 04:04 • 0 comments -
Just soldered new prototype PCB and case
05/20/2022 at 01:39 • 0 comments -
new hardware
05/16/2022 at 04:05 • 0 comments -
auto adjust z axis test
05/16/2022 at 04:04 • 0 comments -
Wow! Distance resolution 0.006mm
05/05/2022 at 03:35 • 0 commentsI did some tests with new board those days, and the result is very good, the distance resolution is 0.006mm~0.01mm in the distance range from 0.5mm ~ 7 mm; and 0.01~0.03 mm in the range from 7mm~10mm. and now write software for the connecting i2c protocol
the first prototype testing
04/27/2022 at 08:05 • 0 comments
