Nozzle Collision Sensing
04/17/2024 at 06:58 • 0 commentsBenefit:
- Avoid the temperature drift.
- Auto z_offset Calibrate
From the data bellow we can see that the temperature drift will only change the z_offset, rise or low the bed mesh, but does not change the bed mesh with this BDsensor. that means the bed mesh is the same even with different temperature.
3. Repeatability: +/-0.005mm
The BDsensorM is coming soon.
01/16/2024 at 09:31 • 1 comment![]()
real time leveling update
11/15/2023 at 10:23 • 0 comments -
My bed needs 900 bed mesh points
08/24/2023 at 02:38 • 0 commentsMy bed needs 900 bed mesh points, but it's quick to do 900 bed mesh points with BDsensor.
Delta printer for marlin
08/16/2023 at 01:32 • 0 commentsDelta printer Fast Bed Mesh with BDsensor for Marlin firmware.
Thanks Botio
08/12/2023 at 10:09 • 0 comments -
Delta printer Testing
08/12/2023 at 10:04 • 0 comments -
No need to modify the klipper source code
08/01/2023 at 06:45 • 4 commentsNo need to modify the klipper source code with latest code on githube for BD sensor.
Fast Bed Leveling test 300mm/s
04/17/2023 at 03:55 • 1 commentafter one week work there's a progress, fast bed mesh for klipper with BDsensor, 300mm/s , klipper source code: https://github.com/markniu/klipper
Klipper Installing
01/23/2023 at 07:00 • 1 commentHere is the beta version of Klipper that support Bed Distance Sensor
https://github.com/markniu/Bed_Distance_sensor/wiki/Installing-for-Klipper
mark
