The final version will have 4 x 18650 Li-ion batteries attached to the rear of the unit. The inside of the bar will be mostly occupied by the array, heatsink, controller, fans, driver, display, and wiring. Placing the batteries externally will avoid cramping other parts and allow enough airflow to keep the array cool.
