This is a very advantageous yet easy to make project. It prevents the battery from overcharging. We call it "Battery Charge Controller".
dadsqsdf.PNGCustom Designed PVC boxPortable Network Graphics (PNG) - 118.67 kB - 05/01/2022 at 09:34 |
Gerber_PCB_CHARGING IND_2021-12-29.zipx-zip-compressed - 46.57 kB - 05/01/2022 at 09:14 |
This Project is named as "Battery Charge Controller".
Benefits:-
This device optimizes voltage differences and offers DC load optimization. 'It offers more output and hence more capacity (Amp). It's an automatic switching circuit that used to control the charging of a battery from any other source. This device limits the rate at which electric current is added to or drawn from electric batteries to protect against electrical overload, overcharging, and may protect against overvoltage.
By following this guide, you will be able to know and make your Battery Charge Controller. This project guide contains the files necessary to help you step by step produce your own Battery Charge Controller. Please follow the steps of the project to get a positive result.
Step 1:- Get your PCB ready!
Talking about electronics
As you can see in the pictures above the PCB is very well manufactured and I’ve got the same PCB design that we’ve made for our main board and all the labels and logos are there to guide me during the soldering steps. You can also download the Gerber file for this circuit from the download link below in case you want to place an order for the same circuit design.
How to calibrate?
We can adjust our power supply in different voltage for different types of batteries.
Step 2: Get all the Components Listed below images.
Step 3: Place all the components on PCB and solder it properly.
Step 4:- Stick the PCB in custom designed box with the help of glue gun.
Final step:- Cover the box and place all the components of PCB on their respective holes or places.
Now your own Battery Charge Controller is ready to use.
Testing:-
For the real time testing I am using my this 12v Lead Acid Battery to discharge the Battery. Here I am connecting a bulb as load to the battery the battery is now almost discharged to 20 % so I am connecting the charger to the controller in order to test overcharging protection system and as you can see it in photos our device works.
New users will also get some coupons while registering at JLCPCB via this blue link.
Thank you for reading this guide, hopefully, this guide provides full steps to help you to create your own Battery Charge Controller. If you have any questions please post them in the comment section below.
