Hackaday.io Hackaday.io
Sign up Log in
stm32 HiFi usb sound card DIY
Black /Green pill stm32f401 , high quality, low noise DAC based on 2 PWM timer channels with virtual software Sigma Delta ADC
samsonov-dimaSamsonov Dima
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
5.9k views
0 comments
73 followers
  • Description
  • Details
  • Files 0
  • Components 8
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
5.9k
0
73
26
Team (1)
  • samsonov-dimaSamsonov Dima
Join this project's team
  • stm32f4audio
hardware
ongoing project
Software
STM32 audio usb RETRO
This project is submitted for
  • Hackaday.com Tip Line
This project was created on 05/02/2022 and last updated 4 years ago.
Description
DIY about $3-$9 (depends number of displays) low cost solution Software low noise DAC based on 2 PWM timer channels with virtual soft Sigma Delta ADC between stream from usb and PWM output. There is implemented "sigma-delta floating point encoder" workaround of native stm32f401 limit 10.5 bits on 44100 Hz (1904 levels=84MHz/44.1KHz ) So, we can have for only $3 ,very low noise , high sound quality solution, which better then most onboard sound cards !
There is implemented virtual software second order sigma delta adc for the shift quantization noise to high frequency. see here (it provide useful links at the end):
https://www.analog.com/media/en/training-seminars/tutorials/MT-022.pdf
But instead one bit ( two levels ) i use more bits (0-MAX_LEVELS) Same technology can be used for esp32 high quality sound rendering.
stm32f401cdu6 version https://github.com/sdima1357/stm32f401cdu6_Audio
stm32f401ccu6 version https://github.com/sdima1357/stm32f401ccAudioNative
Details
Components
  • 1 × stm32f401cdu6 or stm32f410ccu6 green pill board
  • 2 × st7789 240x240 ips display (0,1 or 2optionaly)
  • 1 × connector audio 3.5mm
  • 2 × resistor 100 Ohm
  • 2 × resistor 220 Ohm
View all 8 components
Log In/Sign up to comment
Sign up with Github
OR
A RP2040-based Board with 32-bit Audio Output and 8x 12-bit 1MSPS ADC for creating standalone synthesizers and noise boxes.
Project Owner Contributor
PicoADK - Audio Development Kit
datanoiseDatanoise
A transmitter that broadcasts the time at 1 bit-per-second to radio-controlled clocks
The Watch Tower
mike-burtonMike Burton
LP-2010 AES17 1998 Switching Amplifier Low Pass(low-pass) Filter
yakeyake
Playing 4ch Tracker Music MOD-Files on a "$0.10" MCU.
ModPlay RISC-V
timTim
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "stm32 HiFi usb sound card DIY", please tell us the reason.
Send message
Remove Member
