COMIX-35 Assembly Resources are already well documented.
CDP1802 still widely available. Other chips less so:
CDP1869
CDP1870
CDP1871
2022-06-01
I found two sources for the PCB.
On eBay, https://www.ebay.co.uk/itm/115300569917 for £22.79 + £7.20 postage = £29.99.
If was a third cheaper from a UK supplier, https://www.dcselectronics.co.uk/comix-35.html for £18.50 and chipset for $31.20 (£24.95), so I order it from there.
I found a kit of ICs on eBay.com https://www.ebay.com/itm/114536103330 for $24. It was cheaper and less fuss than sourcing them separately. I paid with my card, as this has a slightly better currency exchange rate than eBay.
ETA 14-17 June for the chips, 11th June for the PCB.
2022-06-08
PCB arrives. I have noticed that the legend on the PCB indicates '74LS245' while the parts list specifies 74HC parts (or 74HCU for the crystal oscillator circuit). The original COMX used mix of 4000 and 74LS series parts. I'm going use CMOS parts with LS switching thresholds, because I have a large stock of 74HCT14, 74HCT86 and 74ACT574 chips.
2022-06-10
Parts arrive. They supplied a 74HC04 instead of the recommended 74HCU04.
2022-06-12
Fitted many parts. Soldered the logic and RAM chips directly, because they are too cheap to warrant sockets these days and sockets introduce unreliability. I have fitted sockets for the DIP40 chips.
2022-08-19
Received low-height crystals from https://www.ebay.co.uk/itm/265237934281 which will make the board look a bit nicer and less vulnerable to knocks.
2022-08-25
Received crystal insulating washers.
Keith
