2022-06-08
PCB arrives. I have noticed that the legend on the PCB indicates '74LS245' while the parts list specifies 74HC parts (or 74HCU for the crystal oscillator circuit). The original COMX used mix of 4000 and 74LS series parts. I'm going use CMOS parts with LS switching thresholds, because I have a large stock of 74HCT14, 74HCT86 and 74ACT574 chips.
2022-06-10
Parts arrive. They supplied a 74HC04 instead of the recommended 74HCU04.
2022-06-12
Fitted many parts. Soldered the logic and RAM chips directly, because they are too cheap to warrant sockets these days and sockets introduce unreliability. I have fitted sockets for the DIP40 chips.
2022-06-18
Board currently looks like this:
Lacking most of the passive components. I had many 100n decoupling capacitors available. I have the chips for the sockets, but won't fit them until all other components are fitted, to avoid exposure to static discharge.
I plan to modify the project to input characters from a USB module instead of the keyboard, so I can enter programs by pasting text into a terminal emulator.
Keith
