Arranged the SMD components as per the schematic diagram, so that it will be easier for placing the components on the PCB.
First I have applied the solder paste by using a solder paste syringe.
Placed the components by using tweezers
Cooked the PCB using my Hot Plate.
Soldered the Through Hole Components : 3 x JST connectors, Push Button Switch, and USB-C Socket
