I have tested the circuit as per the above setup. The PCB is working as expected. I have also tested the backup time and the following are the actual results
1. Mode-1: LOW Brightness - 26 Hrs
2. Mode-2: MEDIUM Brightness - 12 Hrs
3. Mode-1: HIGH Brightness - 7 Hrs
