1Purchase Off-The-Shelf Components
Purchase the off-the-shelf components per the "Components" section of this Hackaday project or the "eBOM" spreadsheet of the OpenDendrometer engineering notebook.
2Order the OpenDendrometer PCB
Order the OpenDendrometer PCB using the latest version of the Gerber and Drill file package located in the "Files" section of this Hackaday project.
3Order the Laser Cut Plywood Parts
Order the OpenDendrometer laser cut parts using the latest version of the laser cut DXF file located in the "Files" section of this Hackaday project. Cut from 1/8in baltic birch plywood.
4Assemble the OpenDendrometer PCB
5Modify the Digital Tire Depth Gauge
6Secure the Digital Tire Depth Gauge to the OpenDendrometer PCB
7Upload the OpenDendrometer Sketch to the Arduino
Upload the latest version of the OpenDendrometer Arduino sketch (located in the "files" section of this Hackaday project) to the Arduino Pro Mini board.
8Drill Holes in the Aluminum Angle
9Assemble the Enclosure
10Mount the OpenDentrometer to the Tree
