Example Project 5 - 3x3x3 LED cube - New Thoughts
A project log for The Atmega Hearth
Lets imagine a cheap core for all your breadboard µC Projects.
stefan-xpStefan-Xp 11/05/2014 at 20:165 Comments
Too sad i did't take my time to figure out the progmem feature of the Atmega.
My newer Idea is to use the EEPROM to store the animation Data. It would have at least a few pros ;-)
+ 256kB for 1€ or less
+ You could load the current data directly from eeprom
+ you always can upgrade to 512kB or 1024kB... if its still not enough you can add more EEPROMs :-) (My largest Animation took 567 Byte)
Cons:
- One Part more on the BOM
- You need a PC tool to write the EEPROM (USB connection o.s.)
What do you think?
Rich text editor
Stefan-Xp wrote 11/05/2014 at 21:13 point
Where do i find your github stuff regarding the gameboy printer?
davedarko wrote 11/05/2014 at 23:22 point
Im too lazy to copy it with my tablet... check my profile page, there is a link to my github and there must be the gameboy printer code.
davedarko wrote 11/05/2014 at 23:25 point
Should not be that much. Just include the avr/pgm stuff and place the progmem stuff..https://github.com/davedarko/GBPrinter/blob/master/examples/GBPrinter_buffered_plus/GBPrinter_buffered_plus.ino
Stefan-Xp wrote 11/06/2014 at 21:15 point
Thank you, i think i will have another look at that :)
davedarko wrote 11/05/2014 at 20:32 point
You could check my github stuff on the gameboy printer but this sounds interesting as well :) i always wanted to programm my own gameboy cartridges and those are eeproms in the smallest cartridge version...
