I just found a Mini Kit Falcon on Amazon ... https://www.amazon.de/gp/product/B000KSJOSG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I had to enlarge my Order for free shipping ... so i added it to my Basket.
Steps:
- Build a AtmegaHearth, which works. I had a bit of issue with this this time --> The Crystal is needed to flash the µC. But at least i have now 3 more assembled boards...
- Solder some Magnetwire to some SMD LEDs.
- Add some Resistors to the AtmegaHearth (Thombstonestyle).
- Check if all LEDs are working (Worked suprisingly well)
- Programm the µC with a small Programm which lights the LEDs and lets the Engine LEDs flicker a bit (Kinda SW PMW)
- Match and Glue the LEDs into the Falcon.
I think it looks nice. What do you think?
... could have done be better.
... the Base it a bit poor.
... the µC is a bit oversized for such a simple Task but it is still extendible
... the Falcons "Metall pieces" are a bit too translucend for the light
looks great :)
Thank you ;-)
