Standoff_Sprued.stl
UNTESTED "Release candidate" file for standoffs required to mount the switch plate to the frame. 3D print this.
Standard Tesselated Geometry -
721.27 kB -
07/14/2022 at 08:06
Download
SwitchPlate.dxf
UNTESTED "Release candidate" file for the switch plate, the panel that holds the keyboard switches. Laser cut this from 1.5 mm aluminium.
AutoCAD DXF -
53.08 kB -
07/14/2022 at 08:06
Download
JackPanel.dxf
UNTESTED "Release candidate" file for the panel that holds the connectors (USB etc). Laser cut this from 1.5 mm aluminium.
AutoCAD DXF -
25.48 kB -
07/14/2022 at 08:06
Download
TopPanel.dxf
UNTESTED "Release candidate" file for the top panel of the enclosure. Laser cut this from 1.5 mm aluminium.
AutoCAD DXF -
26.97 kB -
07/14/2022 at 08:06
Download
TopPanel_Acrylic.dxf
UNTESTED "Release candidate" file for the acrylic cover for the top panel of the enclosure. Laser cut this from 1.5 mm aluminium.
AutoCAD DXF -
26.51 kB -
07/14/2022 at 08:06
Download
BottomPanel.dxf
UNTESTED "Release candidate" file for the bottom panel of the enclosure. Laser cut this from 1.5 mm aluminium.
AutoCAD DXF -
23.48 kB -
07/14/2022 at 08:06
Download
