• 8kB rom
    korneliuszo05/31/2022 at 19:54 0 comments
    I've realized that real NE1000/2000 cards had 2764 as option rom which is 8kB.
    I've resized firmware and I barely fit into new constrain.
    I use https://www.tindie.com/products/weird/isa-8-bit-ethernet-controller/ as real hardware and it allows 16kB roms which I've initially targeted.
    BTW I've added broadcast packet with mac sent when boortom wakes up after geting IP from DHCP server.
  • Emulated floppy works
    korneliuszo05/25/2022 at 13:07 0 comments
  • ​MFM disk ddrescue
    korneliuszo05/18/2022 at 15:47 0 comments
    PYTHONPATH=$PWD nbdkit -f --filter=blocksize python nbd.py ip=192.168.1.105
     nbd-client 127.0.0.1 10809
    $ ddrescue /dev/nbd0 pb8088rescue.raw pb8088rescue.nfo
    GNU ddrescue 1.26
    Press Ctrl-C to interrupt
         ipos:   42205 kB, non-trimmed:    2336 kB,  current rate:   21845 B/s
         opos:   42205 kB, non-scraped:        0 B,  average rate:   17365 B/s
    non-tried:   12518 kB,  bad-sector:        0 B,    error rate:       0 B/s
      rescued:   27364 kB,   bad areas:        0,        run time:     26m 15s
    pct rescued:   64.81%, read errors:       59,  remaining time:         10m
                                  time since last successful read:          0s
    Copying non-tried blocks... Pass 1 (forwards)
         ipos:    65536 B, non-trimmed:    3621 kB,  current rate:    5006 B/s
         opos:    65536 B, non-scraped:        0 B,  average rate:   15878 B/s
    non-tried:    6619 kB,  bad-sector:      512 B,    error rate:    2275 B/s
      rescued:   31978 kB,   bad areas:        1,        run time:     33m 34s
    pct rescued:   75.74%, read errors:       93,  remaining time:         18m
    Copying non-tried blocks... Pass 2 (backwards)
         ipos:   196608 B, non-trimmed:    4268 kB,  current rate:       0 B/s
         opos:   196608 B, non-scraped:        0 B,  average rate:   15468 B/s
    non-tried:    3145 kB,  bad-sector:      512 B,    error rate:   32768 B/s
      rescued:   34804 kB,   bad areas:        1,        run time:     37m 30s
    pct rescued:   82.43%, read errors:      110,  remaining time:          9m
                                  time since last successful read:          2s
    Copying non-tried blocks... Pass 4 (backwards)
         ipos:   14417 kB, non-trimmed:    5460 kB,  current rate:   21845 B/s
         opos:   14417 kB, non-scraped:        0 B,  average rate:   14750 B/s
    non-tried:        0 B,  bad-sector:      512 B,    error rate:       0 B/s
      rescued:   36758 kB,   bad areas:        1,        run time:     41m 32s
    pct rescued:   87.06%, read errors:      138,  remaining time:          6m
    Copying non-tried blocks... Pass 5 (forwards)
         ipos:   26082 kB, non-trimmed:        0 B,  current rate:   20480 B/s
         opos:   26082 kB, non-scraped:   990208 B,  average rate:   13730 B/s
    non-tried:        0 B,  bad-sector:    62976 B,    error rate:       0 B/s
      rescued:   41166 kB,   bad areas:      123,        run time:     49m 57s
    pct rescued:   97.50%, read errors:      260,  remaining time:         54s
    Trimming failed blocks... (forwards)
         ipos:   14658 kB, non-trimmed:        0 B,  current rate:    9216 B/s
         opos:   14658 kB, non-scraped:        0 B,  average rate:    8450 B/s
    non-tried:        0 B,  bad-sector:   499712 B,    error rate:       0 B/s
      rescued:   41719 kB,   bad areas:      138,        run time:  1h 22m 16s
    pct rescued:   98.81%, read errors:     1113,  remaining time:          0s
                                  time since last successful read:         n/a
    Scraping failed blocks... (forwards)
    Finished
  • Video rendering on CGA (~9FPS)
    korneliuszo05/17/2022 at 18:43 0 comments
  • 1dither example
    korneliuszo05/15/2022 at 12:57 0 comments
  • CGA noise dithered image
    korneliuszo05/15/2022 at 11:59 0 comments
