8kB rom
05/31/2022 at 19:54 • 0 commentsI've realized that real NE1000/2000 cards had 2764 as option rom which is 8kB.
I've resized firmware and I barely fit into new constrain.
I use https://www.tindie.com/products/weird/isa-8-bit-ethernet-controller/ as real hardware and it allows 16kB roms which I've initially targeted.
BTW I've added broadcast packet with mac sent when boortom wakes up after geting IP from DHCP server.
Emulated floppy works
05/25/2022 at 13:07 • 0 comments -
MFM disk ddrescue
05/18/2022 at 15:47 • 0 commentsPYTHONPATH=$PWD nbdkit -f --filter=blocksize python nbd.py ip=192.168.1.105
nbd-client 127.0.0.1 10809
$ ddrescue /dev/nbd0 pb8088rescue.raw pb8088rescue.nfo GNU ddrescue 1.26 Press Ctrl-C to interrupt ipos: 42205 kB, non-trimmed: 2336 kB, current rate: 21845 B/s opos: 42205 kB, non-scraped: 0 B, average rate: 17365 B/s non-tried: 12518 kB, bad-sector: 0 B, error rate: 0 B/s rescued: 27364 kB, bad areas: 0, run time: 26m 15s pct rescued: 64.81%, read errors: 59, remaining time: 10m time since last successful read: 0s Copying non-tried blocks... Pass 1 (forwards) ipos: 65536 B, non-trimmed: 3621 kB, current rate: 5006 B/s opos: 65536 B, non-scraped: 0 B, average rate: 15878 B/s non-tried: 6619 kB, bad-sector: 512 B, error rate: 2275 B/s rescued: 31978 kB, bad areas: 1, run time: 33m 34s pct rescued: 75.74%, read errors: 93, remaining time: 18m time since last successful read: 0s Copying non-tried blocks... Pass 2 (backwards) ipos: 196608 B, non-trimmed: 4268 kB, current rate: 0 B/s opos: 196608 B, non-scraped: 0 B, average rate: 15468 B/s non-tried: 3145 kB, bad-sector: 512 B, error rate: 32768 B/s rescued: 34804 kB, bad areas: 1, run time: 37m 30s pct rescued: 82.43%, read errors: 110, remaining time: 9m time since last successful read: 2s Copying non-tried blocks... Pass 4 (backwards) ipos: 14417 kB, non-trimmed: 5460 kB, current rate: 21845 B/s opos: 14417 kB, non-scraped: 0 B, average rate: 14750 B/s non-tried: 0 B, bad-sector: 512 B, error rate: 0 B/s rescued: 36758 kB, bad areas: 1, run time: 41m 32s pct rescued: 87.06%, read errors: 138, remaining time: 6m time since last successful read: 0s Copying non-tried blocks... Pass 5 (forwards) ipos: 26082 kB, non-trimmed: 0 B, current rate: 20480 B/s opos: 26082 kB, non-scraped: 990208 B, average rate: 13730 B/s non-tried: 0 B, bad-sector: 62976 B, error rate: 0 B/s rescued: 41166 kB, bad areas: 123, run time: 49m 57s pct rescued: 97.50%, read errors: 260, remaining time: 54s time since last successful read: 0s Trimming failed blocks... (forwards) ipos: 14658 kB, non-trimmed: 0 B, current rate: 9216 B/s opos: 14658 kB, non-scraped: 0 B, average rate: 8450 B/s non-tried: 0 B, bad-sector: 499712 B, error rate: 0 B/s rescued: 41719 kB, bad areas: 138, run time: 1h 22m 16s pct rescued: 98.81%, read errors: 1113, remaining time: 0s time since last successful read: n/a Scraping failed blocks... (forwards) Finished
Video rendering on CGA (~9FPS)
05/17/2022 at 18:43 • 0 comments -
1dither example
05/15/2022 at 12:57 • 0 comments -
CGA noise dithered image
05/15/2022 at 11:59 • 0 comments
