1Introduction of Amazon AWS IoT
Amazon AWS IoT is a cloud IoT service platform that enables you to connect devices to AWS Services and other devices, secure data and interactions, process and act upon device data, and enable applications to interact with devices even when they are offline. (https://aws.amazon.com/iot/how-it-works/)
The service architecture of AWS IoT:
![1]()
(Picture from http://docs.aws.amazon.com/iot/latest/developerguide/aws-iot-how-it-works.html )
In the architecture, Ameba belongs to the upper-left “Things” block. A TLS secure channel will be established between “Things” and the MQTT Message Broker. Afterward, “Things” and “Message Broker” communicate using MQTT Protocol via this secure channel. Behind the “Message Broker”, the “Thing Shadows” keeps messages temporarily when Ameba is offline and sends the control message to Ameba the next time it is connected. The “Rules Engine” allows you to place restrictions on the behavior of Things or to connect Things to other services of Amazon. -
2Setup AWS Management Console
First, create an account and sign up for AWS IoT service: https://aws.amazon.com/
Afterwards, log in to the Amazon Management Console and click “IoT Core” found under services -> Internet of Things.
![1]()
Then you will enter the homepage of AWS IoT. To offer the best service quality, Amazon offers servers in different regions for users to choose from. Click the region dropdown menu at the upper-right:
![1]()
Choose a nearby region.
![1]()
Then from Services, go to Onboard then Get Started.
![1]()
Enter the main page of AWS IoT. Under the Onboard a device, click Get started.
![1]()
Click Create single thing.
![1]()
Fill in “ameba” on the name field. Attributes represent the status of Ameba.
![1]()
Under the searchable thing attributes. The value of the attributes can be updated directly by Ameba or by the control side and control side can request Ameba to set the attribute to desired value. Here we add an attribute named “led” with value “0” and click “Next”.
![1]()
Click Skip creating a certificate at this time and then Create thing
![1]()
Next, click Policy¸ and create a policy. The policy is used to restrict the functions that a “thing” can do, it can limit the MQTT actions or specific topics that can be performed. Learn more about policy:
http://docs.aws.amazon.com/iot/latest/developerguide/authorization.html
Here we do not place policy on Ameba. Fill in “amebaPolicy” in the Name field, “iot:*” in Action field and “*” in resources field. Then “Allow”. Finally, click “Create”.
![1]()
Next, we have to setup the TLS certificate. You can choose to user-defined or generate a certificate by AWS IoT. In this example we click Create Certificate to generate a TLS certificate.
![1]()
You can see 4 Links. Please download each of the link, “public key”, “private key”, “Certificate” and “rootCA”. After downloading the 4 files, click Done and go back to the certificate main page.
![1]()
Click Attach a policy in the Actions dropdown menu.
![1]()
Choose amebaPolicy and click attach.
![1]()
Then go back to the Actions drop down menu at the top right of the certificate homepage, click on Attach thing, select the thing “ameba” you just created when the window below appears, then click on Attach.
![1]()
Go back to certificate main page and click Certificate and click Activate in the Actions drop down menu.
![1]()
Next, click Manage, and click Things, then click “ameba” the thing we created just now. Click on Interact and View settings.
![1]()
Find out the information of Rest API Endpoint to set Amazon Alexa: — REST API endpoint: In the value “https://a1a7oo4baosgyy.iot.us-east-1.amazonaws.com/things/ameba/shadow”, the part “a1a7oo4baosgyy.iot.us-east-1.amazonaws.com” is the MQTT Broker server address. — MQTT topic: The value “$aws/things/ameba/shadow/update” represents the MQTT topic we will use in the AWS IoT Shadow service (if we use MQTT only, without AWS IoT Shadow service, then we can specify other topic names). It is recommended to use “$aws/things/ameba/shadow/update” here.
Ameba setting
3Setup Realtek AMB21/22/23 Dev Board
Open “File” -> “Examples” -> “AmebaMQTTClient” -> “Amazon_AWS_IoT_Basic”
In the sample code, modify the highlighted snippet to reflect your WiFi network settings.
![1]()
Then, fill in the Thing_Name as “ameba”.
![1]()
And the MQTT broker server address we found earlier in AWS IoT.
![1]()
Next, fill in the rootCA used in TLS. Download and make sure the downloaded rootCA contents conforms to the rootCA used in the sketch.
![1]()
Next, fill in the certificate we created in the AWS IoT Console (i.e., client certificate), usually, its file name ends with “-certificate.pem.crt” (e.g., “efae24a533-certificate.pem.crt”). Open the certificate with a text editor, and adjust its format as follows to use in the sketch: – Add the new line character “\n” at the end of each line. – Add a double-quote at the beginning and the end of each line. – To concatenate each line as a string, add “\” at the end of each line. – The last line ends with a semicolon. Adjust the format of the private key in the same way and add it to privateKeyBuff.
![1]()
4Compilation and Upload
Upload the code and press the reset button on Ameba once the upload is complete. Open the serial monitor in the Arduino IDE and observe as Ameba connects to the AWS IoT server and sends updates on the LED state variable.
![1]()
5Alternatives
The Ameba boards can also retrieve the current LED status variable from the AWS shadow. This is done by sending a message to the “shadow/get” topic. Refer to the Amazon_AWS_IoT_with_ACK example code for more information.
6Code Reference
The change of led state: In this example, we use the GPIO interface to control the led. We set led_pin to 10 and led_state to 1 by default in the sample code.
pinMode(led_pin, OUTPUT); digitalWrite(led_pin, led_state);
Set up certificate: Note that we use the WiFiSSLClient type of wifiClient.
WiFiSSLClient wifiClient;
WiFiSSLClient inherits Client, so it can be passed as the parameter of PubSubClient constructor. Next, set up TLS certificate required in connection.
wifiClient.setRootCA((unsigned char*)rootCABuff); wifiClient.setClientCertificate((unsigned char*)certificateBuff, (unsigned char*)privateKeyBuff);
Configure MQTT Broker server Then MQTT PubClient set MQTT Broker server to connect
client.setServer(mqttServer, 8883); client.setCallback(callback);
Connect to MQTT Broker server: In loop(), call reconnect() function and try to connect to MQTT Broker server and do the certificate verification.
while (!client.connected()) {Subscribe & Publish Next, subscribe to topics.
for (int i=0; i<5; i++) { client.subscribe(subscribeTopic[i]); }There are some common topics: “$aws/things/ameba/shadow/update/accepted”, “$aws/things/ameba/shadow/update/rejected”, “$aws/things/ameba/shadow/update/delta”, “$aws/things/ameba/shadow/get/accepted”, “$aws/things/ameba/shadow/get/rejected” Related documentation: http://docs.aws.amazon.com/iot/latest/developerguide/thing-shadow-data-flow.html Then publish current status:
sprintf(publishPayload, "{\"state\":{\"reported\":{\"led\":%d}},\"clientToken\":\"%s\"}", led_state, clientId); client.publish(publishTopic, publishPayload);Listen to topic and make response: In the callback function, we listen to the 5 subscribed topics and check if there are messages of “/shadow/get/accepted”:
if (strstr(topic, "/shadow/get/accepted") != NULL) {If there is, the message is from the control side. If the attribute state in the message is different from current state, publish the new state.
updateLedState(desired_led_state);
7More References
Please visit the following websites for more details about the board & other examples:
- AmebaIoT Official Website: https://www.amebaiot.com/en/
- AmebaIoT Official FB Page: https://www.facebook.com/groups/AmebaIoT
- AmebaIoT Forum: https://forum.amebaiot.com/
Splendide_Mendax
