DSLR-Camera-slider-Using-Arduino
Hello friends in this video I have made a 2-Axis camera slider,
by using arduino stepper motor and some aluminium extrusion profile.
A rotary encoder and 0.96" oled display used for user interface
VIDEO
This the link of complete video you can watch the video from here where I have demonstrated complete steps
in order to build this cool arduino based DSLR Camera slider.
COMPONENTS USED
2 pieces Nema 17 motor
10mt of GT2 open belt
1 piece of 200mm GT2 closed belt
3 pieces of GT2 pitch toothed pulley, 20 teeth
1 piece of smooth idler pulley
4 pcs of POM coated ball bearings
1 piece of limit switch microswitch
1 piece of camera holder
optional: slot nuts
CIRCUIT DIAGRAM
CUSTOM PCB
L293D = 2 pieces
LM7809 = 1 piece
LM7805 = 1 piece
10.1uF electrolytic = 1 piece
1N5408 = 1 piece
1N4007 = 1 piece
led = 1 piece
resistance of at least 470 Ohm = 1 piece
Arduino Nano = 1 piece
Oled display = 1 piece
Encoder = 1 piece
A4988 controller = 2 pieces
socket 8 + 8 = 1 piece
PCB female pin header connectors
screw connectors for printed circuit boards
I have designe a PCB which is multipurpose and order it from JLCPCB
I always prefer JLCPCB.com for my PCB needs, JLCPCB.com have best deals for their customers $2 for 1-4 Layer PCBs, free SMT assembly monthly.
SMT Assembly service of JLCPCB.com is cherry on top now get your PCB fully assembled and save your time and money Select components for your PCB from there Parts Library of 200k+ in-stock components they are offering $30 valued New User coupons & $24 SMT coupons every month $8.00 setup fee, and $0.0017 per joint
Now no need to order components separately for you PCB and get free from stress of soldering them on PCB just try PCB SMT assembly service and get you PCB with components pre assembled and ready for the project
👉 Try PCBA service of JLCPCB.com and save your time and money, get PCB ready for project, 200K+ components in library of JLCPCB.com as well as 3rd party parts to choose from. Assembly will support 10M+ parts from Digikey, mouser
👉 $30 valued New User coupons
👉 $24 SMT coupons every month
For more detials & offers please visit JLCPCB.com
Click here to visit JLCPCB.com
I have used the 12mm birch wood to made this side blocks, the dimensions are 60mm on top
and 80mm on bottom, and have 20mm grove at the top center,
in this grove we can place our 20x20 alu. extrution profile.
This is the main part of our project this are the 20 x 20 Alu. extrution the length is as per your need means how long you want to travel camera you can keep length as per that.
I have used two aluminium extrusion of 20x20 cross section size you can use 20x40 size as well
This is the camera slider platform
it have four V shape wheels on the all four corners this wheel fit in the grove of 20 x 20 alu extrusion profile.
I made this platform using 4 mm wood there is also a provision for nema 17 stepper motor.
this motor will pan the camera in 180 degree horizontally
This is the control unit box which I 3D printen in PLA filament
its size is 75 x 55 mm I have placed my PCB inside this box and I placed a rotary encoder and
small OLED screen on the cover of this control unit box
This rotary encoder and small OLED screen is helpfull for user interface and to display data on the screen
Arduino Code
#include <Wire.h> #include <Adafruit_GFX.h> #include <Adafruit_SSD1306.h> #include <AccelStepper.h> #include <MultiStepper.h> #include "bitmap.h" #define limitSwitch 11 #define PinSW 2 #define PinCLK 3 #define PinDT 8 #define OLED_RESET 4 Adafruit_SSD1306 display(OLED_RESET); AccelStepper stepper2(1, 17, 16); // (Type:driver, STEP, DIR) AccelStepper stepper1(1, 15, 14); MultiStepper StepperControl; long gotoposition[2]; volatile long XInPoint=0; volatile long YInPoint=0; volatile...Read more »
