The Less-is-More (LiM) Cluster Board is a minimalistic Power over Ethernet (PoE) carrier board for the Raspberry Pi (RPi) Compute Module 4 (CM4). On a small footprint it features the following:
- RPi Pi Compute Module 4 (CM4) support (both versions with and w/o eMMC - Lite version)
- PoE Gigabit RJ45 port (GbE)
- USB-C (USB 2.0) for CM4 module flashing (power + data)
- toggle switch for boot/flash mode
- microSD card slot
- 2232 and 2241 M.2 M-key socket dedicated for NVMe PCIe SSD drives
- Fan Pins
- SDA, SDC, YCC, GND pins for OLED Displays
Prototypes are currently in production ETA June/July '22
You can read more about the full LiM cluster project here - My Custom (Automated) LiM Kubernetes Cluster · l00nix's RPi blog (loonix.ca)
