This device is extremely convenient and affordable. You can make this device for your office as well as for your home also. This device will make your life way easier. By using this Smart Electric Board, you will be no longer dealing with those hassling wires. By using this Smart device, you can switch off lights or fans without moving from your position which will save your energy and electric bills. So, This device is also a powerful Energy-saving Solution.
By following this guide, you will be able to know and make your Smart Electric Board. This project guide contains the files necessary to help you step by step produce your own Smart Electric Board. Please follow the steps of the project to get a positive result.
Step 1:- Get your PCB ready!
Talking about electronics
After making the circuit diagram I transformed it into a PCB design to produce it, to produce the PCB, I have chosen JCLPCB the best PCB supplier and the cheapest PCB provider to order my circuit. with the reliable platform, all I need to do is some simple clicks to upload the Gerber file and set some parameters like the PCB thickness color and quantity. I’ve paid just 2 Dollars to get my PCB after five days only, what I have noticed about JCLPCB this time is the "out-of-charge PCB color" which means you will pay only 2 USD for any PCB color you choose.
Related Download Files
As you can see in the pictures above the PCB is very well manufactured and I’ve got the same PCB design that we’ve made for our main board and all the labels and logos are there to guide me during the soldering steps. You can also download the Gerber file for this circuit from the download link below in case you want to place an order for the same circuit design.
2
Get all the Components Listed below images.
3
Place all the components on PCB and solder it properly.
