Wiring Done! It works!!!
05/31/2022 at 02:35 • 0 commentsThere is still work to do on the UnoJoy side but so far it works! Some of the buttons are wired to HAT and two axis are currently doing nothing: Flaps and Fuel Tank Selector. But that was to be expected as UnoJoy was loaded with its default example. But this is amazing stuff, I'm really happy with this! Nice weekend project!
Test Fit Done - Some modifications suggested
05/30/2022 at 19:12 • 0 commentsEverything fits together as intended. Some pieces were either too tight or a little on the loose side so I decided to print some again.
Unfortunately, I made the linear sliders a little bit too tight so that they bind a little bit when fully extended. I'll change that in CAD but for now, I'll leave my sliders like this as it's good enough.
The trim wheel holder has to be changed, though, as some manual modifications cause it to grind against the enclosure now and I really don't like that.
Putting things together... part 1
05/30/2022 at 16:48 • 0 commentsAnd somewhere underneath is the box I'm gluing right now...
Painting the Enclosure
05/30/2022 at 02:23 • 0 commentsThis is a very rough paint job but to be honest, I don't really care much if this box has a smooth surface or not. In the end it's gonna be used for a while and then gets either rubbed smooth naturally or via a patina of dust :)
I should probably mention that the paint is still drying in this picture. It will be uniform matte black when dry.
Saving the print actually worked!
05/30/2022 at 02:21 • 0 comments -
Saving a 10h Print Mid-Flight.... in terror
05/29/2022 at 19:51 • 0 commentsI was happily staring at the print when I realized that some parts where missing on the print bed. One part I thought but it turned out to be two parts.
In my terror, I tried various things to get the filament to stick to the BuildTak build plate again but nothing worked. I even tried to fill the gap with electrical tape when I realized that I just threw away a bunch of raft that I thought I'd never use. As the universe so dictated, I was exactly at the same height as my raft stock was thick!!! I quickly cut a piece to shape and packaging taped it to the build plate in haste!
Not 10 seconds later the print head came back over and printed on the newly added raft... IT WORKED!!! What???
That was also the moment when I found that a second part was gone so I tried to save the rest of the print from that, too... Another piece was cut and taped to the build plate. I was getting a little nervous, though, because the print already added another two layers and it might be too high up to print on that new raft... but IT ALSO WORKED!!! Hell yeah!
Laser Cutting the Enclosure
05/29/2022 at 19:45 • 0 comments -
Go Full Plate 3D Print!
05/29/2022 at 17:20 • 0 commentsLet's do this!
First Print Tests
05/29/2022 at 15:01 • 0 commentsAlternatite Static Switch Assembly
Flaps Assembly
Timo Birnschein
