1. Open the "cloner" software. Click on the "Config" button.
2. In the "INFO" tab:
Set "Board" to "x1000_sfc_nor_32mb.cfg"
Set "BaudRate" to "115200"
Set "UART" to "uart2_pd"
3. In the SFC - Partition tab, configure the partitions as the following:
4. In the SFC - spibase tab, deselect the "All erase" option.
5. In the "POLICY" tab, config the entries as the following. Use the "..." button to select the image files.
6. Click on "Save As". You can use a informative filename.
7. Click on the "Start" button.
8. Hold the left function button of the device, and connect the device to the PC via USB. The battery must be removed. The flashing will start in a moment.
18
Finished!
Install the battery to the device. It will power on automatically.
