1solder the headphone wires to the Arduino
solder the headphone wires to the Arduino pins. For simplicity, I used the pins 2,3,4,5,6,7 for letters, and 11,12,13 for function buttons.
2Add the headphone wires to the glove using a needle.
3Add the conductive thread
I'm not good at sewing, so I tried to have a big surface of the conductive thread, also, I tried different shapes, but they all work fine.
4Connect the headphone wires to the conductive thread
I simply made a knot between the headphone wires and the conductive thread. And I used a simple threading wire in order to secure the knot.
5That's it, now, just upload the Arduino code and enjoy.
The Arduino code can be found in the github repo. For instance, the code is just for test, and not the final version.
Nait Malek Youssef
