New Trancievers
07/31/2023 at 00:50 • 0 comments![]()
New Transceivers specifically for 12-24v Neopixels.
These are fused at 7.5 amps and have a dedicated power connector for the 12-24v line
Finally a full systems test, 200ft of cable
07/03/2022 at 00:03 • 0 commentsTest with 200ft of ethernet cable -
Testing transceivers
06/26/2022 at 00:31 • 0 comments -
Differential Transceiver Rev 2
06/22/2022 at 22:05 • 0 commentsboard has been populated enough for testing
Selectable Transceiver Rev 2
06/21/2022 at 06:53 • 0 commentsImprovements
-Fixed backwards VCC and GND labels
-Fixed backwards A and B labels
-made enough room for an optional SL connector behind ethernet jack
-Added labels to the output channels
-Changed ethernet jacks to Tab-Up style
-Added bling
Differential RJ45 hub Rev 2
06/19/2022 at 00:08 • 0 commentsImprovements
-Reran the traces to the ethernet jacks to make it used the T-568B ethernet cable wiring
-Added bling
-Shrunk board size
Differential transmitter Rev 2
06/16/2022 at 23:47 • 0 commentsreran the traces to the ethernet jacks to make it use T-568B wiring and added some labels to the input channels
side lit neopixel boards
06/13/2022 at 06:05 • 0 comments![]()
side lit neopixel breakout boards came in yesterday
