Taranis gimbal joystick
06/09/2022 at 06:57 • 0 commentsThis device was made to make use of unused Frsky taranis x9d gimbals and to have an xinput compatible device.
More information how to make this can be found on thingiverse and YouTube.
Design files are also available in the files section.
8 key macropad
06/09/2022 at 06:53 • 0 commentsThis was my first DIY input device but still in use as a stream and macro controller
Its based around a maxkeyboard acrylic switch tester (not sure if its still sold...) and an arduino micro.
Later i have added a 3d printed case to make it a bit cleaner.
Files are found in the files section if you really want to make this. The arduino code may be helpful for other projects.
Single key
06/09/2022 at 06:49 • 0 commentsThis is just a digispark based single key "keyboard" with different macro modes and a custom Wipf keycap.
STL and more information can be found on thingiverse![]()
3D printed mouse
06/09/2022 at 06:44 • 0 commentsThe mouse was made out of the joke of having a mouse with mechanical keyboard switches and to see how well that would work.
The result is a not very ergonomic mouse you probably can't reproduce without finding a PAN3101 sensor.
Fortunately the PAN3101 is found in many cheap optical mice so that was the choice for that project.You can find the files for this project in the files section.
Yannick (Gigawipf)
