1Convert the picture to ASCII art
First you need to find a photo that has simple background, then use the python script to convert it to txt file
2Put the txt file into SD card
3Use the Arduino code found in the Github to flash the MCU
You may follow instructions here to get started,
https://www.amebaiot.com/en/amebad-mini-arduino-getting-started/
