All starts with the background photo posted here... that was in 2017. the picture shows a discarted Gantry from CT system, at junkyard. in that moment, i was sad for the loss. i repair/fixed many systems like this.
The most probable failure to decommissioned a system is Image Processing Unit Hardware. Here a way to Rescue it, using Open Source solutions
What format does the gantry/detector produce it's projections in, and also what are the physical connections from the gantry/detector that you interface to the frame grabber?
Very interesting project! I wish you success - it's always admirable to see someone trying to repair/reuse equipment.
