Another fork of TinyBasic for teensy ++2.0 - with LCD, SDCard, WIFI, 2 serialports & user buttons
The orginal goal of this project was to make a smarter & powerfull(er) serial com to my Canon X-07 (by adding support to UARTs & uSDCards).
It 's now happening ...
And I hope some other ideas will come soon....
It look nicer now !
As original TinyBasicPlus implementation doesn't support STRING variables,
I started a little-experimental support for those.
I added 4 string vars. $1 to $4 (I know : it's not the casual formalism for BASIC string values, but it was simplier to modify the interpreter by this way... maybe later, will do better)
So I can now transform my little board into a notepad, typewriter.. or simply displays what user inputs...
(GitHub is up to date...)
Today, I made a mainboard (to replace my breadboard layout) & started to build an enclosure
I used a mono-layer perfboard & some DIP socket in order that each component can be replaced if broken....
Today, I added 3 user buttons to the board (UP,DOWN,OK)
Then I improved my shell with 3 new functions :
So I can now create some simples menus :)
I now looked at #Xts-uBasic. Thats really cool. Followed and liked. So you may add video output? That would be awesome to see.
I like this project, and idea, but have you considered adding support for an external monitor? It seems like the screen would be small. Just a thought.
By the way, I like the case. I should do that for my projects.
Hi, thanks for your support, Yes the screen is tiny, I'm currently working on an other project : #Xts-uBasic that currently use a VGA-TEXT interface & I'm trying to use a RPIZERO as HDMI text & graphics output.... (maybe it will make samething a day :) )
