Back to the roots ...
12/02/2016 at 09:28 • 0 commentsThe orginal goal of this project was to make a smarter & powerfull(er) serial com to my Canon X-07 (by adding support to UARTs & uSDCards).
It 's now happening ...
And I hope some other ideas will come soon....
The box is finished
11/30/2016 at 11:11 • 0 commentsIt look nicer now !
Added String variables support
11/30/2016 at 07:58 • 0 commentsAs original TinyBasicPlus implementation doesn't support STRING variables,
I started a little-experimental support for those.
I added 4 string vars. $1 to $4 (I know : it's not the casual formalism for BASIC string values, but it was simplier to modify the interpreter by this way... maybe later, will do better)
So I can now transform my little board into a notepad, typewriter.. or simply displays what user inputs...
(GitHub is up to date...)
Started Mainboard & enclosure
11/27/2016 at 18:22 • 0 commentsToday, I made a mainboard (to replace my breadboard layout) & started to build an enclosure
I used a mono-layer perfboard & some DIP socket in order that each component can be replaced if broken....
Added User Interactions
11/26/2016 at 18:11 • 0 commentsToday, I added 3 user buttons to the board (UP,DOWN,OK)
Then I improved my shell with 3 new functions :
- KEY() that returns the state of the 3 btns (1,2,4)
- LCCLS that clear the LCD
- LCPRINT <lineNum>,<expr> that prints a line on the LCD
So I can now create some simples menus :)
