11STEP 8: SD Card and Prepping to pull
STEP 8: SD Card and Prepping to pull.
- Load the 600mm suggested speed gcode onto the SD card.
- Load Filament into Nozzle. - Go to Control, Temperature, Nozzle and turn to 210.
- Go back to Main Prompt to watch the heat rise. - Load Filament to Spooler.
- Go to Print from TF - and use 600mm - Suggested Pull speed for the MK5 DualGeared Single Motor Puller.
Until a new manual is written for the Recreator 3D MK5Kit : Ender 3 Please find the following manual for the MK3Pro, which should give you an idea on the overall process of how to get started with the unit. http://recreator3d.com/manual
Congratulations!
You’ve Completed
The Recreator 3D Build!
What Will You Recreate? Thanks for Recycling!
12DONATIONS ARE WELCOME!
Scan the QR to Donate and help with Future Projects!
Consider supporting the good work Joshua R. Taylor
does by donating or sharing with others who'd like to help.
