Using a blender to turn failed prints into grains
01/31/2024 at 20:20 • 0 commentsStill my favorite way to turn failed prints into plastic granules is using a blender and a sieve. Let's have a closer look at what is happening in the blender and what properties the end product has and must have:
Larger grains into smaller ones
06/13/2022 at 07:40 • 0 commentsMy first approach to get grains smaller than 2mm from the mix coming out of a blender was to use a DIY sieve. The second one is a mixture of sieving and grinding:
The solution is made of 3mm steel with a 8.5mm hole drilled and a 8mm threaded rod.
The steel plate with a hopper is mounted on the base plate and the threaded rod is in the chuck of a drill press. By moving the drill up and down WITHOUT the drill rotating, the grains are forced down through the hole. Even at the highest point, the threaded rod is still in the hole of the steel plate, so that only grains of a certain size, fitting in the gap between threaded rod and hole can be squeezed through. Larger grains will get crushed by this process, so that this is a combination of sieving and grinding.
Of course, the raw material filled into the hopper must first be crushed into small pieces with a blender. The advantage is, that larger particles coming out of the blender can also be processed in one run. There is no need to put the large granules back into the blender.
Blender & Sieve: A quick solution for my Direct Granules Extruder
06/13/2022 at 07:10 • 0 commentsTo get raw material for my Direct Granules Extruder, I am using a commercial blender and a DIY sieve to get the raw material needed. The main property the granules must fulfill is a size of no more than 2mm. This is critical, because larger sized granules lead to clogging of my existing extruder design. This must be relatively small to be able to extrude plastics in small quantities as required in 3D printing.
To get the correct grain size, I have drilled 2mm holes on the bottom of a tin can.
This works fine with failed PLA and PETG prints.
Norbert Heinz
