JPEG Image - 2.52 MB - 06/14/2022 at 22:03
Preview
keyset.kicad_pcb
PCB source for KICAD
x-kicad-pcb - 95.79 kB - 06/14/2022 at 13:19
Download
keyset.sch
Schematic source for KICAD
x-kicad-schematic - 3.77 kB - 06/14/2022 at 13:19
Download
Doug's button to keycode mapping from the Augment project.
JPEG Image - 1.83 MB - 06/14/2022 at 13:18
Preview
engelbart.ino
Source code, much of which is from the USB host Teensy code written by Paul Stoffregen.
x-arduino - 12.52 kB - 06/14/2022 at 13:18
Download
engelbart-piano-key-spacer.scad
Two of these center the keys in the case, one on each end.
x-openscad - 629.00 bytes - 06/14/2022 at 13:14
Download
engelbart-piano-key-spacer.stl
Standard Tesselated Geometry - 39.73 kB - 06/14/2022 at 13:14
Download
engelbart-piano-key.stl
Five of these are the keys that press on the switches
Standard Tesselated Geometry - 143.51 kB - 06/14/2022 at 13:14
Download
engelbart-piano-key.scad
x-openscad - 609.00 bytes - 06/14/2022 at 13:14
Download
keyset-topcase.stl
Keyset top case. Holds the 3.3mm rod that the keys hinge on.
Standard Tesselated Geometry - 170.17 kB - 06/14/2022 at 13:09
Download
keyset-botcase.stl
Keyset bottom case. Holds the electronics.
Standard Tesselated Geometry - 314.12 kB - 06/14/2022 at 13:09
Download
keyset-spacers.stl
Keyset spacers. Fits between the PCB and topcase.
Standard Tesselated Geometry - 98.00 kB - 06/14/2022 at 13:09
Download
keyset.scad
Source for the case STLs.
x-openscad - 4.65 kB - 06/14/2022 at 13:09
Download
