Hackaday.io Hackaday.io
Sign up Log in
Acrylic led matrix
A led matrix that can be seen through and can be viewed both sides
estEst
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2.3k views
3 comments
763 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
2.3k
3
763
24
Team (1)
  • estEst
Join this project's team
ongoing project
Related lists
blinky projects
blinking lights
This project was created on 11/26/2016 and last updated 7 years ago.
Description
This led matrix uses individually addressable RGB led strips wide only 4mm and a distance between the LEDs of 16.6mm.
On top of each LED there is a square piece of clear acrylic that accommodate the LED strip and shines the light on its sides. Each pixels has its isolated square piece of acrylic and this prevents the light to diffuse to the nearby pixel.
The led strip is driven by Arduino loaded with the Glediator sketch slightly modified and driven by a Python program on the PC that i am currently developing.
Project Logs
Collapse
  • first attempts of programming the visualizzation
    Est • 12/04/2016 at 17:01 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
Ember Leona wrote 10/15/2018 at 05:44 • point
I like this idea. They make cool effects by rotating strips of led lights. With rotation and fast refresh you can make really cool stuff. The problem to over come is when rotating the wires self destruct so using a magnet to make connection might help or using rotors.
Taylor wrote 03/29/2017 at 15:24 • point
Such a beautiful and clean design, I love it!
Est wrote 03/31/2017 at 04:36 • point
Thank you!
How to led
Project Owner Contributor
How to led
protocolProtocol
electronica
diseño de un circuito de luces led
danfer-adriandanfer adrian
Its Attiny85 with red and Yellow Superbright LED
Candle Light Fading
schuppSchupp
LED strip music visualiser on a jar
LED Jar
mackemacke
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Acrylic led matrix", please tell us the reason.
Send message
Remove Member
