First program works! In a cycle I'm doing ADD+ADA operations on 25Hz!
Program:
0: NOP
1: ADA+0xFF00 - set Address register to 0xFF00
2: ADD+1 //increment value in current memory cell
3: ADA+1 //shift current memory cell number
//repeate last two instruction 16 times, because writing inner loops in brainfuck is brainfuck enough :)
33: ADA-0xF //return AP to 0xFF00 memory cell
34: JNZ-0x21//if current cell is Not Zero, return IP to number 1 (which would be skipped due to pc arch).
All instructions are repeated.
Artem Kashkanov
Excellent! Congratulations! Is it reliable at 25Hz? That's quite fast.
The sound is impressive. You feel the machine working hard.
I'm a big fan of your work. (I would have prefered to see progress on the Decatron computer, but it doesn't matter).
It's very rewarding when you integrate/assemble all parts together, and everything works like expected, like a charm. I'm sure you currently experience this feeling after several month of hard work.
Thanks!
It's fully reliable on 25Hz - Maximum frequency is 40Hz, but "Hello world" application works unstable on this frequency - need to do some improvements to fix.
Yesterday I launched "Hello world!" application, written on brainfuck (code from Wikipedia) and it works perfect. And yes - when I saw "Hello world!" in console output I was happy - Hard work is done and now I just need to polish some parts and put "Done" label to this project and became working on Dekatron computer :)
I understand, I try to work like you : I try to finish one big project before really beginning a big new project (even if I accept collecting parts and ideas for future projects).
Maybe I will come back to "homemade CPU - computer" in a few months... if yes, it would be a fully transistored CPU-computer.
Congratulations, that is truly mesmerising!
thanks a lot!
