Impulse sequencer ruins all plans
10/22/2018 at 07:24 • 0 commentsI made impulse sequencer which generates 16 impulses where each next impulse goes with pause after the previous one.
Current pause rate is ~700us and 10 stages gives me 7ms. Last 16-th impulse stay high only after 11 ms!. This is a disaster. I can not deliver 100 Hz frequency on this rates. 50 Hz would be the good prize.
One workaround is to raise voltage from power supply
Instruction Decoder Wire-wrapped
10/07/2018 at 21:10 • 0 commentsStarted Relay computer logic block. Done instruction decoder part - It get 4-bit instruction number and decode it to a signal on a propel line.
All schematic eat 11 relays and 5 diodes.
Power line +5V improvement
10/02/2018 at 09:00 • 0 commentsI found significant voltage drop on high speed, so I added direct copper line 0,25x11 mm to each data module. I can be sure that this would be enough to good power delivery. Power line resistance now is less than 10 mOm.
Reed relay music
09/26/2018 at 08:43 • 0 comments -
Reed Relay MIDI music box (Up to E3 note)
09/24/2018 at 07:47 • 0 commentsConnect MIDI keyboard and use it as a frequency generator. So when I press some note, BFPC start do increment on it's frequency so we can play some music, e.g. The Imperial march from Star Wars
First relay calculations!
09/22/2018 at 08:54 • 4 commentsSet CarryIn=1, TMP_EN=1, IP_EN=1 and send alternating pulses to TMP_WR and IP_WR.
So it's just increment tests.
Relay Blocks interconnection 100Hz test
09/20/2018 at 06:32 • 0 commentsJust Store some value in TMP register and Send impulse to CarryIn and Latches
More power!
09/19/2018 at 17:45 • 0 comments -
Power Up Indicators
09/14/2018 at 21:04 • 0 commentsAdded +48V and +1V for VFD indicator modules. BFPC became 20% cooler than yesterday
Power Up!
09/13/2018 at 19:21 • 2 commentsLet's power Up all registers.
15W for handling and 15W for storing. 5V 3A :)
