The 8bit keyboard.
This keyboard inputs characters in 8bits.
Eight toggle switches are used to enter ASCII codes bit by bit.
To achieve operation similar to that of a regular keyboard, it has a function to stock up to three input keys and a key lock function to keep the stocked characters active at all times.
How to use.
Key Input
"a" is the ASCII code 0x61 ( 011000001 ).If you set it with the keyboard, it will look like this.
  1.  Set the "a" ( HEX: 0x61, BIN: 01100001 ) key.
  2.  Press the key button.
"a" is sent.
Multiple inputs
You can press multiple keys at the same time by using the stock button.
*Press the key button to release the stock.
  1. Set the "shift" ( HEX: 0x81, BIN: 10000001 ) key.
  2. Press the stock button.
  3. Set the "a" ( HEX: 0x61, BIN: 01100001 ) key.
  4. Press the key button.
"A" is sent.
However, if you set "A" ( 0x41 ), you can set "a" ( 0x61 ) without the need for a "shift" ( 0x81 ) key.
Key Lock
With a key lock, you hold down a stocked key.
*When you unlock the key, the stock will be released.
  1. Set the "shift" ( 0x81 ) key.
  3. Lock the key.
  4. Set the "a" ( 0x61 ) key.
  5. Press the key button.
"A" is sent
  1. Unlock the key.
"a" is sent.
DEMO
8bitkeyboard_arudino_src.zip
source code.
Zip Archive - 3.77 kB - 08/31/2023 at 03:32
Download
Enclosure_Drawing.pdf
Drawing for laser cutting. Wood used is MDF 4mm.
Adobe Portable Document Format - 5.77 kB - 08/31/2023 at 03:29
Preview
substrate.pdf
Adobe Portable Document Format - 55.30 kB - 08/31/2023 at 03:23
Preview
circuit_diagram.pdf
Adobe Portable Document Format - 72.08 kB - 08/31/2023 at 03:23
Preview
  • 1 × ESP-WROOM-32
  • 8 × 15A 220V ON/OFF toggle switch Development Kits, Boards and Systems / Development Kits and Boards
  • 1 × Key Switch ON OFF Lock Switch
  • 1 × LED (Red) Electronic Components / Misc. Electronic Components
  • 2 × Push switch
View all 7 components
View all 5 project logs
bgolab wrote 06/25/2022 at 15:02 • point
I would add small lcd display to show the char before sending it out;)
Wing Tang Wong wrote 06/24/2022 at 19:50 • point
wait.. what about support for unicode?
AIRPOCKET wrote 06/22/2022 at 01:13 • point
It's amazing what you can achieve with only 11 keys.
That's a 10% mechanical keyboard.
I love this so much!
