Product Specifications
General
Type: USB Tester
Architecture: For all electronics
Display Type: Full Colour RGB LCD Display
Product Model: UM24
Interface Type: USB (Universal Serial Bus)
Test Subjects: Voltage, Current, Power, Capacity, Resistance, Energy Detention, Fast Charging Identification, Data Analysis (through the 10 memory channels), and Temperature.
Voltage Measurement Accuracy: ± (0.2% + 1 digit)
Current Measurement Accuracy: ± (0.8% + 3 digits)
Temperature Range: - 10°C-85°C / 0°F-100°F
Temperature Measurement Error Range: ± 3°C / ± 6°F
Screen Brightness Setting Levels: 0 - 5 levels
Auto Screen Off Time Minutes (when idle): 1 - 9 minutes
Time Measurement Range: 0 - 99 hours, 59 minutes, 59 seconds
Data Storage Groups: 10 groups
Quick Charge Recognition Modes: QC2.0 and QC3.0
Refresh Rate: 2Hz
Power
Voltage Measurement Range (Operating Voltage): 4.50 - 24 volts
Voltage Measurement Resolution: 0.01 volts
Voltage Graphing Range: 4.5 - 24 volts
Current Measurement Range (Operating Current): 0 - 3 amps
Current Measurement Resolution: 0.001 amps
Current Graphing Range: 0 - 3 amps
Capacity Accumulation Range: 0 - 99999 mAh
Energy Accumulation Range: 0 - 99999 mWh
Load Impedance Range: 1.5 - 9999.9Ω
Weight and Size Dimensions
Product Weight: 19g
Product Size (L x W x H): 71.2 x 31.8 x 11.3 mm
Product Review
In my opinion, this device is extremely useful when working with modern USB devices such as computers or power banks, as you can monitor, analyse and detect what is going through, to your load. Some of my positive aspects of this device include:
1. Its solid and durable structure, especially with its sandwich-style design for a more compact item.
2. The multiple features it has to measure every aspect which is going through the meter and coming out into the load.
3. The graphing function for the voltage and current, this function can be very useful to see change over time.
4. The very high resolution, colour RGB LCD display which displays all of the information with amazing quality and accurate measurements, accompanied by the software programmed in this module. This is also one of my main reasons to why I enjoy using this product.
ICStation Product Page
Check out the product here: http://www.icstation.com/product_info.php?aid=294&products_id=13232
For purchases from ICStation, use this code for a discount:
Code: Simics
Discount Amount: 15% off
Max. Use: 1 (one per user)
Amount Limit: 300
Be sure to check out the UM24 USB Meter Tutorial by clicking here.
Amazing opportunities
Also, be sure to check out PCBWay, a leading manufacturer and distributor in PCB design and manufacturing. They have amazing prices and excellent quality in their services, so don't miss out on them! Plus, PCBWay has an amazing website, online Gerber viewer function and a gift shop so make sure to check out their links below:
PCBWay Free Online Gerber Viewer Function: https://www.pcbway.com/project/OnlineGerberViewer.html
PCBWay Gift Shop: https://www.pcbway.com/projects/gifts.html
Enjoy! Contact us for any inquiries!
Nikola Manolov
Ludwin
Meticulous Technologies
Alex Klimaj
