This project is sponsored by PCBWAY. It is world fastest pcb manufacturing company.
You Will get FREE prototype pcb from PCBWAY. So do not be late to register and place your first order from PCBWAY
If you want to order pcb from PCBWAY . CLICK IN THE LINK BELOW:
https://www.pcbway.com/QuickOrderOnline.aspx?from=electronicsworkshops
Code
#include <stdio.h>
#include <string.h>
#include <DHT.h>
//Change the API key to yours
String Apikey = "***************";
#define DEBUG true
#define LTE_RESET_PIN 6
#define LTE_PWRKEY_PIN 5
#define LTE_FLIGHT_PIN 7
#define Sensor_PIN 3 //D3-DHT11
DHT dht(Sensor_PIN,DHT11);
void setup()
SerialUSB.begin(115200);
//while (!SerialUSB)
; // wait for Arduino serial Monitor port to connect
Serial1.begin(115200);
//Serial1.begin(UART_BAUD, SERIAL_8N1, MODEM_RXD, MODEM_TXD);
pinMode(LTE_RESET_PIN, OUTPUT);
digitalWrite(LTE_RESET_PIN, LOW);
pinMode(LTE_PWRKEY_PIN, OUTPUT);
delay(100);
digitalWrite(LTE_PWRKEY_PIN, HIGH);
delay(2000);
digitalWrite(LTE_PWRKEY_PIN, LOW);
pinMode(LTE_FLIGHT_PIN, OUTPUT);
digitalWrite(LTE_FLIGHT_PIN, LOW);//Normal Mode
delay(5000);
/*ModuleState = moduleStateCheck();
if (ModuleState == false) //if it's off, turn on it.
digitalWrite(PWR_KEY, LOW);
delay(3000);
digitalWrite(PWR_KEY, HIGH);
delay(10000);
SerialUSB.println("Now turnning the SIM7600 on.");
sendData("AT+CCID", 3000, DEBUG);
sendData("AT+CREG?", 3000, DEBUG);
sendData("AT+CGATT=1", 1000, DEBUG);
sendData("AT+CGACT=1,1", 1000, DEBUG);
sendData("AT+CGDCONT=1,\"IP\",\"apn\"", 1000, DEBUG);
//sendData("AT+CIPSTART=\"TCP\",\"www.mirocast.com\",80", 2000, DEBUG);
SerialUSB.println("4G HTTP Test Begin!");
dht.begin();
delay(1000);
void loop()
//--------Get temperature and humidity-------------
float h = dht.readHumidity();
float t = dht.readTemperature();
SerialUSB.print("Humidity: ");
SerialUSB.print(h);
SerialUSB.println("%");
SerialUSB.print("Temperature: ");
SerialUSB.print(t);
SerialUSB.println("*C");
delay(1000);
//-----------HTTP---------------------
String http_str = "AT+HTTPPARA=\"URL\",\"https://api.thingspeak.com/update?api_key=" + Apikey + "&field1=" + (String)t + "&field2=" + (String)h + "\"\r\n";
SerialUSB.println(http_str);
sendData("AT+HTTPINIT\r\n", 2000, DEBUG);
sendData(http_str, 2000, DEBUG);
sendData("AT+HTTPACTION=0\r\n", 3000, DEBUG);
sendData("AT+HTTPTERM\r\n", 3000, DEBUG);
delay(5000);
bool moduleStateCheck()
int i = 0;
bool moduleState = false;
for (i = 0; i < 5; i++)
String msg = String("");
msg = sendData("AT", 1000, DEBUG);
if (msg.indexOf("OK") >= 0)
SerialUSB.println("SIM7600 Module had turned on.");
moduleState = true;
return moduleState;
delay(1000);
return moduleState;
String sendData(String command, const int timeout, boolean debug)
String response = "";
Serial1.println(command);
long int time = millis();
while ( (time + timeout) > millis())
while (Serial1.available())
char c = Serial1.read();
response += c;
if (debug)
SerialUSB.print(response);
return response;
A promotion for a PCB manufacturer and uncommented code is called "learning"?
