I went through the code and added some ifdefs to make it more likely to operate with these scopes but I have no way to test it.
10/12/2022 Update The latest .zip file (HP54542_ctl_Multi_Build_10_12_2022.zip) has the changes required to compile for the 5452x family of scopes in it.
It also has changes to make it easier to build in a MINGW/Windows evironment using the National Instruments 488-2 driver. See the aa_notes file for details.
