This mod changes the main LCD panel controller signals to switch automatically between PAL and NTSC timings based on the input frequency.
Beware:
It should work for both NTSC and PAL LCDs but my model was NTSC, so different modifications may be needed for PAL.
It does not change the color carrier in any way, so this works only for RGB video, not composite (it works, but the image is B/W in the non-native standard).
Details
I will add firmware source code and details about how it works...
