The map currently is 8x8 bits with a floor and wall tile. 8 bytes are used to represent a map. Each byte codes for one line horizontally. The map shown in the main project image is the following:
wall: .db 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff, 0xff
floor: .db 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
main_map: .db 0xff, 0x81, 0x81, 0x1, 0x81, 0x81, 0x81, 0xfb
To copy this map to the display buffer the following code is used:
draw_map:
ldi xl, low(buffer)
ldi xh, high(buffer)
ldi yl, low(buffer)
ldi yh, high(buffer)
ldi zl, low(2*main_map)
ldi zh, high(2*main_map)
movw r25:r24,z
ldi r21, 128
ldi r22,0
ldi r18, 8
tile_no:
movw y,x
movw z,r25:r24 ; load map
lpm r16, z ; bit map/line value
adiw r25:r24, 1
ldi r17, 8 ; 8 bit/tiles per line
draw_line:
lsl r16
brcs draw_wall
draw_floor:
ldi zl, low(2*floor)
ldi zh, high(2*floor)
lpm r19, z
rcall draw_tile
rjmp end_tile
draw_wall:
ldi zl, low(2*wall)
ldi zh, high(2*wall)
lpm r19, z
rcall draw_tile
end_tile:
dec r17
brne draw_line
rcall next_line
dec r18
brne tile_no
ret
