Made a 50 Ohm coax driver card (DRIVE50).
- "TTL" Level Line driver
- 50 or 75 Ohm output impedance
- BNC or SMA output connector
- 10K pull-up on input
- Card is non-inverting
- 1.5V-5.5V power
- Typically 3.3V or 5V
- 3-pin right angle 0.1" pitch input connector
- (4) 4-40 mounting holes
Installed in Box
Card works well.
